Hi jdmhonda,
If the engine starts and stall immediately, it is most probably an idling problem
Did it start again after stalling?
Would it stall if you press the gas pedal to get the rpm higher?
If Yes to the above, then you need to check for fuel pressure.
Saturday, June 7th, 2008 AT 6:14 AM
