1991 Acura Integra Integra cranks up then dies
DETODD30170
  • 1991 ACURA INTEGRA
1991 Acura Integra 4 cyl Front Wheel Drive Manual 200K + miles
My integra has recently cranked then dies, after a few tries it cranks and all is fine. Yesterday it cranked and died then cranked up and was fine. Then as I was driving home it died (something it has never done) now it will crank but dies again. I thought it might be a fuel filter problem but the parts guy thinks its a ignition issue.
Saturday, March 14th, 2009 AT 2:35 PM
KHLOW2008
  • 41,814 POSTS
Hi detodd30170,
If the dash lights are not indicating when the engine stalled after cranking, the problem is caused by the ignition switch.
If dash lights are showing, then it could be a fuel issue, most likely the PGM-FI main relay.
Check the following link and let me know what is missing so we can proceed with rectification.
https://www.2carpros.com/kpages/first_things.htm
Monday, March 16th, 2009 AT 8:37 AM
