I've been the sole owner of a 1990 Integra LS. Recently I've have had problems with getting the engine to continue to run after starting. Situation is, after starting, driving to a destination and shutting off the car, upon restarting it will start but quickly cut off. This requires waiting for several minutes before finally starting again after several attempts.
I've cleaned the IACV, changed the fuel filter, replaced the iginition wires, rotor, cap and plugs.
I suspect this is an electrical problem similar to the replacement of what used to be the condenser on older cars but not sure.
What do you think? Thanks
SPONSORED LINKS
Tuesday, September 7th, 2010 AT 9:05 PM
