1990 Acura Integra stall
REDSOLIS
  • 1990 ACURA INTEGRA
Engine Performance problem
1990 Acura Integra 4 cyl Front Wheel Drive Automatic
I start car anytime of day. With no problem. I go to restart car and put into gear shut down. Restart no problem. Please advise
Monday, July 7th, 2008 AT 4:45 PM
KHLOW2008
  • 41,814 POSTS
Hi redsolis,
What is the idlng rpm?
Does operating AC affect the idling speed?
Is there any check engine light showing when engine is running?
If idling rpm is below 700 and no check engine light is showing, you need to clean the throttle body, idle adjust screw, EACv and fast idle valve. After doing all those, you need to readjust idle screw with engine at operating temp.
Wednesday, July 9th, 2008 AT 12:57 AM
