When you say that I should "turn on the ignition", do you mean turn fully to actually start the engine, or just turn the ignition until the power is fully on? Or does it make a difference? I have tried completely turning the ignition repeatedly, but I have not stopped short and just "powered" the ignition repeatedly. I will give that a try (the next time I am in that situation) and see what happens.
Also, just to make sure I understand, vapor lock would not occur in my vehicle unless the relay is not working properly? I was also considering new spark plugs, but the engine seems to be getting plenty of voltage, as it turns over just fine.
One last thing I just thought of; it has been idling very low (intermittently), but runs fine when accelerating. I was thinking that perhaps my fuel pump is going bad. Could that explain why it would not start in hot weather, yet starts fine the rest of the time?
Thanks again.
Tuesday, January 24th, 2017 AT 8:27 PM
