1993 Acura Integra Automatic 150000 miles
I think I did something, but I don't know what. The other day I drove my car home and knew I was low on gas. It was not on "E" but the orange light did come on for a few seconds and went off (which according to the manual means I have 2.6 gallons or less of fuel). I parked, and the next day I came outside and moved the car a few feet to under the carport because I didn't want snow to get on it. Well, the next day when I came outside and tried to start the car it would crank but not turn over! It's not too cold outside, in the high 20's, so I don't think this is a problem. I decided to try to jump the car. This after several attempts did not work either, although one time she got started, but barely for about 5-10 seconds, and eventually sputtered out. So then I decided to get about 2 more gallons of gas and see if it was low gas causing the problem. Still, cranks but does not turn over. I noticed that the battery, ABS and oil lights are on if I turn on just the dashboard, but I'm not sure if that means anything. I want to make sure it's not something I can do myself before getting the tow truck out here. Thanks for your help!
SPONSORED LINKS
Saturday, November 29th, 2008 AT 5:24 PM
