1992 Acura Integra driverside power window switch
260,000 MILES • 4 CYL • 2WD • MANUAL
BIGMACK6666
Hi! I have a problem with my driverside power window switch. For some reason driverside power window switch doesn't work for eather window but when i use the passenger side switch it works. i have checked all the fuses under the hood and under the dash. i even bought a new fuse box for under the dash. My drivers power mirror still work though. i checked for power going to my door and there isnt except to the mirror. Why is this and what can i do to get my window to work again? Please get back to me as soon as possible. thank you!
Apr 18, 2008 at 7:20 AM
JEREMIAH
  • 217 POSTS
since you checked all the fuses, see if you have power thru fuse 7, under the dash,while pressing the switch in either direction.if you don't then its the power window relay, located in the same fuse box. if you do, then it's the driver's switch itself that's bad.
that's assuming that the harnesses are good.
Apr 23, 2008 at 12:32 PM
