1991 Acura Integra will not start
123GIVENJEFF
  • 1991 ACURA INTEGRA
  • 4 CYL
  • MANUAL
  • 130,000 MILES
My 1991 integra will not srart sometimes and the problem is getting worse. I replaced the distributor and the main relay and still have the problem what could it be thanks Jeff
Thursday, August 13th, 2009 AT 3:39 AM
Next time it refuses to start do below to determine if its fuel or spark problem that is causing it.
Get a helper disconnect a sparkplug wire or two and ground it to the engine have helper crank engine over-do you have a snapping blue spark? If so you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors.
Tuesday, January 24th, 2017 AT 7:05 PM
