Why would my s3 light flash while cranking then stop and now it stays on when cranking and now it wont start
Monday, May 19th, 2008 AT 4:30 AM
THEBIGGMCDOG
MEMBER
I have the problem but the car drives fine, the light flashes, I used to have that problem because sometimes it did not want to start. The light stays on but the car drives fine. The reason ur car does not start is probably youre fuel pressure regulator. So I suggest if the car will not start you need to change youre fuel pressure regulator.
SPONSORED LINKS
Monday, May 26th, 2008 AT 11:37 AM
KHLOW2008
MECHANIC
The s3 light also the MIL for the transmission so when cranking for long periods, it might flash. It is not the problem, it just tells you something might be wrong
If the engine does not start, you need to verify whether it is the fuel or sparks that are causing the problem.
