1991 Acura Integra no start
COLLEEN SIMMONS
  • 1991 ACURA INTEGRA
  • 4 CYL
  • 21,000 MILES
Wont start sometimes it clicks wont turn over unless jumpd then it runs with radio and amp no prob it has a new battery and my altanator tested fine could this be electrical?
Friday, March 6th, 2009 AT 7:40 PM
F4I_GUY
  • 3,302 POSTS
Yes the problem is electrical.
I would check power and ground cables and connections for corrosion or they may be loose. You may also have a parasitic draw on your battery that is causing it to drain when it sits.
Tuesday, January 24th, 2017 AT 7:06 PM
