A/C clutch not working
  • 52,797 POSTS
It will work as long as you have cold air. The moment it does not have cold air, remove the jumper wire and have the freon system tested for a leak and charged.
https://www.2carpros.com/articles/air-conditioner-leak-detection
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
It will not hurt the compressor.
Thursday, May 28th, 2020 AT 4:16 PM
TONY02
  • 74 POSTS
Okay, thanks. I will just do that then.
Thursday, May 28th, 2020 AT 4:26 PM
TONY02
  • 74 POSTS
I have another question but it’s about a different car it’s a 2004 Ford Explorer do you think you can tell where the reverse gear signal wire is located at? I installed a reverse back up camera and I need to hook that wire up.
Thursday, May 28th, 2020 AT 6:55 PM
  • 52,797 POSTS
Site policy I can only address one vehicle at a time per question.
Can you please start a new question? The reason being; in order for the site to properly index the questions they need to about one issue/vehicle otherwise people will not be able to find the answer to this question under a different subject. The premise of our site is to assist those that need direct help and also provide a resource for others that have the same issue.
For your convenience here is the link: https://www.2carpros.com/questions/new
Make sure you are logged into the site before clicking on the link
Friday, May 29th, 2020 AT 4:08 AM
TONY02
  • 74 POSTS
Okay, will do.
Friday, May 29th, 2020 AT 5:35 AM
