HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Uplander
Climate Control
Air Conditioner
Compressor
Relay
SPONSORED LINKS
A/C compressor will not come on unless relay is jumped
PREV
1
2
3
NEXT
MECHANIC
20 lbs on the low side is the pressure needed to turn on the compressor.
25 to 30 lbs is the number for low side. You need an expansion valve.
The electrical issue is separate
Friday, July 26th, 2019 AT 5:23 AM
JASON123177
MEMBER
The very first thing I done in this process was to change both the front and rear expansion valves.
SPONSORED LINKS
Friday, July 26th, 2019 AT 5:28 AM
MECHANIC
I saw that but the pressure indicates it is not working correctly.
Friday, July 26th, 2019 AT 5:37 AM
MECHANIC
What are the pressures withe the engine off
JASON123177
MEMBER
I will check the pressures when I get home this afternoon and let you know. Thank you again for all of your help! It is very very appreciated!
SPONSORED LINKS
Friday, July 26th, 2019 AT 5:41 AM
MECHANIC
You are welcome
Always glad to help
Friday, July 26th, 2019 AT 5:52 AM
MECHANIC
You are welcome
Friday, July 26th, 2019 AT 5:54 AM
JASON123177
MEMBER
The static pressure on both sides is 100psi
Friday, July 26th, 2019 AT 2:55 PM
MECHANIC
There is something wrong with that front expansion valve.
Saturday, July 27th, 2019 AT 11:11 AM
JASON123177
MEMBER
That’s just wonderful.
Saturday, July 27th, 2019 AT 12:08 PM
MECHANIC
Sorry to tell you that but the pressure indicates that.
Saturday, July 27th, 2019 AT 12:13 PM
PREV
1
2
3
NEXT
Please
login
or
register
to post a reply.
Related Air Conditioner Compressor Relay Content
Air Conditioner Not Working?
Hi, I Have Problem With Air Conditioning System Which Only Blow Normal Air. And Rear Mirrors Control Which Can't Be Turn Up Or Down As...
Asked by
yasserBAHJAT
3 IMAGES
2009
CHEVROLET UPLANDER
A/c Hardware Swap
My A/c Compressor Is Leaking. I Have An Old 2004 Montana With A/c That Works. It Is Going To Be Junked. Will The A/c Components From The...
Asked by
RDubya
2 IMAGES
2007
CHEVROLET UPLANDER
Air Conditioner Blows 100 Deg Air On Max Ac.
Suction Pressure-30 Psi With 50 Deg Ambient Head Pressure-150 Psi Ac Control Module? No Low Presure Switch?
Asked by
mpatten
2005
CHEVROLET UPLANDER
2007 Chevrolet Uplander Air Conditioner
Aa/c Clutch Kicks In When Started But Kicks Out Almost Immediately. The Low Pressure Is 250# With The Clutch Out. High Side Static...
Asked by
Davidwright3
1 ANSWER
2007
CHEVROLET UPLANDER
A/c Turned Off For Engine Safety
I Was Driving On The Highway All Of The Sudden The Steering Wheel Became Really Stiff And A Signal Light Came On That Read Discharge...
Asked by
jazzybear90
1 ANSWER
2007
CHEVROLET UPLANDER
VIEW MORE
Online car repair manuals
