Engine is stalling out while driving
  • 75,992 POSTS
Rescanned the computer by using a scantool/scanner or go to autozone and get it read and comeback with the OBD2 code/s
Monday, September 21st, 2020 AT 12:49 PM (Merged)
PAM COOPER
  • 1997 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 191,000 MILES
Pls refer to subject- engine stalls after 10 miles of driving, and then it acts like a fuel problem and then won't restart untill it's cold. I've replaced the fuel filter, and it has good fuel pressure at injector. Our outside air temp is about 5 degrees. Added 2 bottles of iso heet dry gas and 10 gal of fuel. Suggestions?
JNOVACK
  • 723 POSTS
Inspect EGR Valve Clogged, dirty or improperly functioning or defective egr valve.
Inspect MAP Sensor Improperly connected or faulty m.A.P. Sensor.
Inspect Fuel Pump Improperly functioning fuel pump or circuits
Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s).
Inspect Spark Plug Fouled, damaged or broken spark plug(s).
Inspect PCV Valve Plugged or damaged pcv valve.
SKEETER100000
  • 168,000 MILES
I HAVE A 1997 DODGE CARAVAN AND WHEN I DRIVE FOR ABOUT TEN MINUTES IT SHUTS DOWN AND WONT RESTART UNTIL IT COOLS DOWN OR SIT ABOUT 30 MINUTES. BUT I NOTICED THE INJECTORS ARE STILL RECEIVING PLENTY GAS. IF I SPRAY QUICK START FLUID IN IT IT WILL TRY TO START?
  • 109,755 POSTS
You need to check for spark and fuel to the engine when it won't restart. One will be missing. From that, we will know what system to focus on.
SKEETER100000
WHEN IT WONT RESTART THERE IS PLENTY OF FUEL REACHING THE INJECTORS SO I KNOW ITS NOT THE FUEL. BUT CAN THE COIL PACK MALFUNCTION WHEN IT GETS HOT AND THEN RESTART WHEN IT COOLS DOWN. IVE CHECKED EVERYTHING. PLEASE HELP
  • 109,755 POSTS
Yes to the coil pack and crank sensor.
HALVORSONE
  • 6 CYL
  • 196,000 MILES
Two weeks ago I had the rear brakes replaced on my 1997 Dodge Caravan, when I picked it up it the (service soon light) was on. I drove to the airport over an hour and was gone for a week, I picked the car up yesterday drove with no incident and driving today after the car had warmed up, it continually stalled. After sitting a couple hours, I dove it no problems, until it warms up. I have noticed that the idle is really light, at times I have questioned if it was running, not that it jolted in anyway like it was starving but just I can not hear any engine noise. It also would die during acceleration not only stopped.
  • 109,755 POSTS
Hi:
If the check engine light is on or was on, there is a code set in the computer. I recommend that you take the van to a nationally recognized parts store and have them scan the computer for codes. Most stores will do it for free. The codes they pull will help us identify the problem.
Let me know what you find.
ZAZA
Engine Performance problem
1997 Dodge Caravan 6 cyl Front Wheel Drive Automatic
While driving the engine shuts off. After a few minutes will restart. The same problem occurs after a few minutes of driving. Sometimes even when the car is on park. I have changed the following parts:
Coil, the whole distributor, the map sensor, ignition switch and I have still having the same problem.
What diagnostic do you have?
What is the best car hand held analyzer to buy?
Monday, September 21st, 2020 AT 12:50 PM (Merged)
CARADIODOC
  • 33,873 POSTS
I use Chrysler's DRB3 scanner. It does everything possible, and with a plug-in card, will do anything emission related on any brand of car, '96 and newer, sold in the U.S. They're not cheap over the internet, but I get mine through the dealership I used to work for.
Do you know how to retrieve diagnostic fault codes with the ignition switch? That will get you the codes that will direct you to the circuit or system with the problem, not necessarily the defective part.
Caradiodoc
JODI LYNN
  • 3.8L
  • 6 CYL
  • FWD
  • 220,000 MILES
We drive this van anywhere from forty five miles to sixty miles and it will shut off. I have to let it sit for a few minutes, then I will get me another ten miles (if I am lucky) then it shuts off again. We have already replaced the ECM, what else could it be? I am having to use my fifteen passenger van as a daily driver right now.
CARADIODOC
  • 33,873 POSTS
You have not included any test results or information to start the diagnosis, but one dandy observation is the engine will restart after only a few minutes. A real common cause of this type of stalling on any brand of vehicle is a crankshaft position sensor or camshaft position sensor that is failing by becoming heat-sensitive, but your symptoms do not really match this problem. With those sensors, they typically work okay as long as you keep driving and natural air flow keeps them cool. The problem occurs when a hot engine is stopped for a short period of time, as in when stopping for gas, then the heat migrates up to the sensors and causes one to fail. The other clue is it almost always has to cool down for at least an hour before it works again and the engine will restart.
Your observation of being able to restart the engine after only a few minutes points to a very elusive cause. That is a collapsing pick-up screen inside the gas tank. That blocks fuel flow to the pump. An additional clue to look for is the stalling usually occurs when the largest volume of fuel is being pumped, which is during coasting. The engine will usually run fine at higher speeds and when accelerating. I had this happen to me four times with three vehicles. With one of them, it took me four hours to get through Minneapolis with road construction on all three bypasses, then, once out of the city, my van ran fine the next three hours all the way home, until I started coasting, then it stalled again and I had to wait a few minutes.
You can also identify this cause by connecting a fuel pressure gauge and clipping it under a wiper arm so you can watch it while driving. You'll see pressure drop a little when coasting, but if the screen is plugged or collapsing, pressure will drop abnormally-low. In my case, forty five pounds was normal during coasting, but with the plugged screen, it dropped to twenty pounds when coasting, and stalling and surging showed up at fifteen pounds.
The screen costs around $12.00, but the fuel pump assembly has to be removed from the tank to replace it.
MANGUMMIKE
  • 6 CYL
  • FWD
  • 204,000 MILES
My van died while driving, thought it was fuel pump but it seems to pump. Only pumps for initial prime though, not on cranking. Checked for spark next. No spark! Not really sure where to go from there. Would a crank/camshaft position sensor cause this problem? If you can help me out that would be great.
  • 109,755 POSTS
Are you getting power to the coil? And yes a crank sensor can cause this. However, was the check engine light on?
MANGUMMIKE
Thanks for getting back to me so quickly. After going back to my van dumbfounded, and having checked sensors, fuel pump, etc; I decided to pull the front timing belt cover off the engine. Well, it was a broken belt. Boy, what a job! My water pump has been leaking for some time too so I replaced it while I was at it. Again, thanks. Mike
  • 109,755 POSTS
It sounds like you have the aame type of luck I have. Regardless, I'm glad you got it fixed. Let us know if you have questions in the future, and thanks for using 2carpros. Com.
JEROEN
Transmission problem
1997 Dodge Caravan Automatic
First I want to say that I'm from Belgium and my English isn't that good. I hope I can explain enough to give you an idea of what the problem is.
When I start driving the car there is no problem. The car accelerates very good, no shocking, etc. But when I want to slow down to turn, the car stops running from time to time so the problem doesn't occur constantly. The man who I bought the car from said it had to do something with the computer and he did reset it (he said) but the problem still happens. It might be because I'm not used to drive american automatic transmission cars (I'm pushing the brakes not hard enough or to hard) but personaly I think it is something mechanically. The car doesn't shock or anything like that, it just stops running.
When I looked under the hood to see if there was a lose cable I also checked the power distribution center. I noticed that one of the relays are missing: Automatic Transmission Controller Shutdown. I thought this may had something to do with this problem.
I hope some one can help me with this.
Kind regards,
Jeroen
CH112063
  • 1,320 POSTS
Although you can try installing another relay I believe an electronic scan tool can be plugged in to test and repair your van fairly easily, it is important to drive a safe van, and I don't want anyone to get into an accident. If it was because of a missing relay, the scan tool will pick it up electronically. It is your choice for repair facilities. If you see another mini-van like yours ask the owner where he has his van serviced. Ok good luck
BMRFIXIT
  • 19,053 POSTS
Pushing the brakes hard or not has nothing to do with it,
American made cars very comfortable drive and easy too
now do you have a check engine light on while driving and if so we need to find the codes
if no OBDII reader available to you, we can try and get the codes by cycling the ignition switch on off on off on read p codes in the odometer area if no codes DONE will appear
let us know what you have for codes
also you say it happens but not all the times try and notice if the amount of fuel in the tank makes any different
and if its happening when low on fuel start to suspect fuel pump issue
if not
check IAC valve, clean it and throttle body too
after it stalls does it start right back up or it take time for it to fire back up if it take time suspect ASD relay and or crank sensor
good luck
