1970 Ford Galaxie carburetor problems
  • 109,885 POSTS
Can you see the push rods moving? You have to have stuck open valves for there to be no compression. If, however, they are closed and there is no movement from the push rods (which go to the lifters) either you have a cam that is bad (lobes are gone) or the lifters are completely collapsed. If that was the case, they were collapsed, you would have heard them making noise when the engine was running.
Friday, October 25th, 2013 AT 5:19 PM
PAPAJOHNSLICE
  • 108 POSTS
Well I wasn't able to hear a ticking noise because the car wasn't able to run long enough plus the engine is extremely loud and drowns out all other noises, however the push rods were not moving, so I took off the intake manifold and checked the lifters I suspected were bad, and they were, 3 were collapsed, and now it has new lifters, it got to cold to tweak the engine, but I was able to start it and it ran great except for the carb needs to be adjusted
Friday, October 25th, 2013 AT 11:18 PM
  • 109,885 POSTS
So it's running okay other than the carb adjustment?
Saturday, October 26th, 2013 AT 4:43 PM
PAPAJOHNSLICE
  • 108 POSTS
Yup
Wednesday, October 30th, 2013 AT 5:37 PM
