An automotive engine computer monitor is a small program that runs inside the engine computer or PCM. This program allows time to pass while data is gathered and analyzed, this is due to the cycle of the engine heating up and then cooling down which will cause the data to vary when it comes to emission controls and engine performance. This guide explores the conditions for the monitor system to reset, as well as the reasons the monitors will not reset.
If you know the engine computer monitor is not reset then yon should have a scanner capable of reading such information. If a mechanic is telling you there are not reset and this action needs to be done before a smog inspection then this guide will help, pending monitors will be marked as "Not Ready" on the scanner.
Here is a list of the typical automotive monitor systems present in a computerized automobile, monitors ensure they operate within expected parameters.
Because these monitor depend on cycles of the engine being fully warm up, and then completely cold down, it can take several attempts (days) for the monitor resetting to take place. Within these cycles the engine computer is running internal tests on each system which will reset at individual times. Don't be surprised if it take over 200 miles, and many hot and cold engine cycles to reset all system monitors. There is no "set" procedure for this operation, it just takes time, and each manufacturer is different.
1. The most common reason for a monitor not to reset is a pending trouble code which can be discovered by using an code scanner.
2. If the battery was disconnected the engine computer monitor can reset to a 'Not Ready' status.
3. An engine cooling system thermostat that is stuck open it can cause the monitor not to reset because the engine never achieves its operating temperature, so the computer is constantly waiting.
4. Software updates can be used to repair a bug in the engine computer, if all else fails search Google for possible updates or call the dealer.
This guide knowledge base was created by the 2CarPros Team, and by Ken Lavacot: Automobile repair shop owner and certified master automobile technician of over 30 years. If you have question or need help please ask one of our experts we are happy to help. Please visit our 2CarPros YouTube Channel.
