Will not start and run
227,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
DONALD6809
  • 7 POSTS
When I’d accelerate on the interstate, my truck would jerk back down when I let off the gas and when I’d turn it off. it would start but not turn over unless I held the pedal down. Googled and found a few options and they were to change plugs and wires, cap and rotor, fuel filter, fuel pump, O2 sensors and MAF sensor. So after trial and error, I’ve replaced all of these and still have the same issue except now when I put it in gear, it stalls out. I have no idea what to do now. Neighbor says wires might’ve been crossed and we did our best to swap them around and nothing has changed. Thanks to any that can help!
Feb 8, 2021 at 8:48 AM
  • 110,248 POSTS
The idea that you need to hold the throttle down for it to start indicates it is getting too much fuel. Basically, that stops the injectors from working. Have you checked fuel pressure to confirm the regulator is working? Also, do you have a live data scan tool? If you do, could you provide the short term fuel trims for me and any codes that are present?
If you haven't, confirm the fuel pressure is within the manufacturer's specs. Here is a link that shows how to test pressure:
Take care and God Bless,
Feb 8, 2021 at 10:09 AM
DONALD6809
  • 7 POSTS
Thank you! I had checked the pressure prior to changing the filter, pump and all the sensors but after the plugs and wires and it came back within the right parameters.
Feb 8, 2021 at 12:39 PM
  • 110,248 POSTS
Is it running properly now? If so, I'm glad to hear it. Let me know if you can. If I don't hear from you, please feel free to come back anytime in the future. You're always welcome.
Feb 9, 2021 at 10:24 AM
DONALD6809
  • 7 POSTS
Sat down alone today and realized two wires were crossed and that eliminates the “stalling out in gear” issue. my friend brought his scanner over and it popped up as “temperature coolant sensor” and we popped it off, cranked it and it fired up. so I’m hoping I can get it replaced and run the codes once more and everything runs smooth and right, but thank you very much again! God Bless!
Feb 9, 2021 at 10:35 AM
  • 110,248 POSTS
It sounds like you are on the right track. If you can, let me know the final results. Also, feel free to come back any time in the future if you have questions.
Take care of yourself,
Feb 9, 2021 at 10:45 AM
DONALD6809
  • 7 POSTS
So I’m back. I replaced the temperature coolant sensor and it cleared right up, so I let it idle for about 20 minutes and ran the codes again and the dreaded P0300 code came up. so that’s where I’m at today.
Feb 10, 2021 at 1:54 AM
  • 110,248 POSTS
Did you have the code deleted and it came back? If that's the case, we need to check for vacuum leaks on the engine. I remember that you replaced the fuel pump and filter, so the pressure should be good. If you have a live data scan tool, could you let me know what the short term fuel trims are?
Here is a link that shows how to check for engine vacuum leaks:
Feb 10, 2021 at 5:37 AM
DONALD6809
  • 7 POSTS
I checked for a vacuum leak, but couldn’t find anything but I ran it for a bit after clearing the codes and it came back telling me that cylinder 6 was misfiring and I pulled it, cleaned it up and popped it back in and then it came back saying that cylinder 2 was doing the same. So I did the same and now it seems to be running just as smooth and code and issue free for now. So I’m just gonna hold out for a few days and see if I noticed anything else off. Thank you very much for you help so far!
Donald
Feb 10, 2021 at 7:50 AM
  • 110,248 POSTS
What condition were the spark plugs in when you removed them?
Feb 10, 2021 at 10:43 AM
DONALD6809
  • 7 POSTS
They had some soot on them and were alittle black from it, but I wiped them off and put them back in.
Donald
Feb 10, 2021 at 11:56 AM
  • 110,248 POSTS
Don, if they had black on them, that usually indicates a rich fuel mixture, dirty air filter, or even simply making short trips which prevent the engine from fully warming up. Is there any way you could get your hands on a live data scan tool so we can get the short term fuel trims?
Feb 11, 2021 at 10:08 AM
DONALD6809
  • 7 POSTS
I have a live data scan tool on hand at the time, but it hasn’t pulled any codes up. I just got a new air filter about two months ago, but I haven’t actually driven it a good distance since all this has been replaced. Maybe 5 miles tops.
Donald
Feb 11, 2021 at 11:19 AM
  • 110,248 POSTS
If you have a live data scan tool, go to the live data section. With the engine running, see what the short term fuel trims are. I will be able to tell from them if the fuel mixture is too rich.
Let me know,
Feb 12, 2021 at 7:21 AM
