Won't start after replacing the temp sending unit (to computer)
111,000 MILES • 2.3L • 4 CYL • TURBO • RWD • AUTOMATIC
REGVOKES951
It started and when I went to drive off, it stalled. Tried to start a couple of times and did once but when it did, it ran rough and would not rev when given gas. Now I have a 144 code. It seemed to have a weak spark (yellow color spark). I'm thinking the spark should be a blue color and snap when plug wire is placed close to the engine block?
May 28, 2015 at 5:56 AM
  • 55,770 POSTS
We need to start at the basics such as compression and fuel pressure to see where the failure lies, please check this article and do some test, I'll be here waiting your results, then we can go from there, please follow this link,
The 144 Fuel system load signal (missing or defective) sounds like it could be the pump or relay not working, please test and report back :-)
Best, Ken
May 28, 2015 at 2:02 PM
