1991 Volvo 740 Car won't start
225,000 MILES • 4 CYL • 2WD • AUTOMATIC
MRBILL22
It's not ignition
Tried another fuel pump relay
Fuses good
fuel pump replaced
Whats next?
Aug 9, 2010 at 7:07 AM
  • 75,988 POSTS
Don't quite get it, but do below and let me know your findings we start here
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
Aug 9, 2010 at 8:59 AM
