Will not start after being driven.
190,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
MITCHELL GILBOW
My van will start with no problem after it has set over a long period of time and if it has just been setting at an idle but if it is driven even a few miles it will not start. After being driven it will turn over with no problems and fires but spits then dies. If I keep trying to crank on it it will eventually stop firing. I have done a lot of research online but have not found where anyone has found the problem. Can anyone shed some light on this? Thank you in advance.
Jul 26, 2017 at 12:49 PM
HMAC300
  • 48,601 POSTS
this sounds like a classic fuel pump failure after getting warm. Check fuel pressure with a gauge auto parts rent it.
Jul 27, 2017 at 12:04 AM
