Will not start?
350,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
JASMINE12378
My wife drove it for about a mile after I replaced the crank shaft sensor and when she parked it, it just turned off. Haven't been able to get it running since. But it sounds sluggish, and I replaced the fuel pump and still nothing. Before it started this, I had the starter replaced. I'm running out of ideas.
Sep 20, 2022 at 1:28 PM
  • 110,244 POSTS
Hang in there. We'll get it figured out one way or another.
Here is what I need you to do: See if the engine starts for a couple of seconds and then stalls using starting fluid. If it does, then we know it is a fuel-related issue. If there is no change, I need you to check for spark to the plugs.
Here is a link that explains how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find. This will narrow things down, so we know which direction to go. Also, I am basing this on it won't start. You confused me when you said it sounds sluggish. If it does run, good or bad, let me know.
Sep 20, 2022 at 2:04 PM
JASMINE12378
Yes, it won't start. It sounds sluggish when we turn the key.
Sep 23, 2022 at 10:53 AM
  • 110,244 POSTS
Is it possible for you to record it cranking and upload it for me to hear?
Also, did you try starting fluid or check for an ignition spark at the plugs?
Sep 23, 2022 at 1:44 PM
