After running hot will not start
100,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
REGINAB2997
Ran hot so I turned it off and coasted to side of road. wouldn't start so I got a boost and started right up, filled radiator and went home. Went to crank it had to get another boost and use starting fluid, it started up drove about a mile and parked it. went to go somewhere would turn over but not start not even with boost or starting fluid.
Apr 14, 2019 at 9:53 AM
Good evening,
How bad did it overheat?
https://www.2carpros.com/articles/engine-overheating-or-running-hot
It sounds like you have two issues. One with the battery and the other with the starting.
Can you hear the fuel pump run? Can you check the fuel pressure?
Check for spark as well.
Can you give me the battery voltage?
Apr 14, 2019 at 10:04 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Does the starter still engage and turn the engine? Also, if it does and won't start with starting fluid, check to see if there is spark to the plugs. If there is, I have a feeling the head gasket went and you don't have enough compression for it to run. If it does turn and won't start with starting fluid, it isn't a fuel related issue.
Here is a link that shows how to check for spark:
Here are a few links you may find helpful when checking for spark and the wiring involved:
____________________________________
If the engine will not turn when you try starting it and the battery is good, there is a chance one of the cylinders has filled with coolant from a bad head gasket.
If you find there is spark, then you need to check engine compression to see if there is an issue with a head gasket or warped head. Here are general directions for testing compression. You will need a compression gauge, but most parts stores will lend or rent one to you.
Here are directions for testing compression specific to your vehicle. The manufacturer's specs are included in the directions.
Perform the following steps in order to conduct a compression test for VIN 4:
1. Conduct the following steps in order to check cylinder compression:
1.1. Engine should be at room temperature.
1.2. Disconnect wiring from the ignition module.
1.3. Remove the spark plugs.
1.4. Throttle body valve should be wide open.
1.5. Battery should be at or near full charge.
2. For each cylinder, crank engine through four compression strokes.
3. The lowest reading cylinder should not be less than 70 percent of the highest.
4. No cylinder reading should be less than 689 kPa (100 psi).
Important: The results of a compression test will fall into the following categories:
^ Normal-Compression builds up quickly and evenly to specified compression on each cylinder.
^ Piston Rings-Compression low on first stroke. Tends to build up on following strokes but does not reach normal. Improves considerably with addition of oil.
^ Valves-Compression low on first stroke. Does not tend to build up on the following strokes. Does not improve much with addition of oil. Use approximately three squirts from a plunger-type oiler.
__________________________________-
Let me know if this helps. I realize this is a lot of information, but if you have questions, let me know.
Apr 14, 2019 at 10:11 AM
REGINAB2997
Would the O2 sensor keep it from starting?
Apr 15, 2019 at 6:53 AM
REGINAB2997
I can hear the fuel pump running. I can't check for fuel pressure. about to check the spark plugs now.
Apr 15, 2019 at 6:55 AM
No, to the O2 sensor.
You need to T into the fuel filter to check the actual fuel pressure.
If you spray starter fluid in the air filter, will it start and die?
Apr 15, 2019 at 8:13 AM
