Will not start
107,000 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
BRETTSTER49
I took my car to a mechanic and had him replace the timing belt, valve cover gasket and do a tune up. After I got it back it started to act weird. At times it would not start but it still cranked over. I would turn it over four or five times and then wait for a minute it would start. It did this intermittently for a while and you never knew when it would happen. I took it back to the mechanic to see if he could find the problem. After a day of trying he finally got it to not start. He did some testing and found out that when it would not start the checking engine light did not come on when he turned on the key. He then replaced the main relay which seemed to fix the problem for about a week and the it started to happen again. I bought another ECM from Ebay hoping that was the problem but that did not work. Right now I cannot get it to start no matter what I try. The check engine light does not come on at all now, so I have a large paper weight in the driveway that I cannot start and no way to take it to a mechanic. Help! it is driving me crazy.
Mar 14, 2017 at 7:26 AM
WRENCHTECH
  • 20,758 POSTS
New computers have to be programmed by the dealer before they will work.
Mar 14, 2017 at 8:39 AM
BRETTSTER49
It was not new. It came from a 95 Kia Sportage. And it did start for a few times after replacement. I even tried putting the old ECM back on and nothing. I even replaced the main relay again and that did not work.
Mar 14, 2017 at 8:55 AM
WRENCHTECH
  • 20,758 POSTS
Then you are going to have to track down the issue following the wiring diagram to see where you are losing it. Make sure you check the 30A fuel inj fuse. http://i1198.photobucket.com/albums/aa448/Wrenchtech/78817166.gif https://www.2carpros.com/images/external/78817167.gif
Mar 14, 2017 at 9:02 AM
BRETTSTER49
Could it possibly be either the crankshaft position sensor or the camshaft position sensor are bad?
Mar 15, 2017 at 5:05 AM
WRENCHTECH
  • 20,758 POSTS
Not if the check engine light is not coming on for bulb check. If you have different symptoms now, then anything is possible.
Mar 15, 2017 at 5:08 AM
