Why was this put on to begin with?
Which side of the battery is it hooked to, positive or negative?
Like this, sort of, kind of, maybe?
http://www.wirthco.com/batterydisconnectbatteryswitches/batterydisconnectsquickreleaseswitches.html
Starter could be bad-maybe.
I am thinking a poor connection.
Not enough juice or ground for the starter
Let's look at this stuff first.
See any corrosion?
Grab and twist/see if the there is movement of the cables on the other side of a clamp. Grab twist all battery cable connections to anything (both ends of each cable) There should be no movement!
My link may explain better/ I made pictures at the end of it.
https://www.2carpros.com/questions/1996-chevrolet-tahoe-wont-start-sounds-dead-battery-jumpbox-get-same-reults
The Medic
Jan 13, 2018 at 9:05 AM
