1998 Mercury Sable will not start or even turn over
TARA56
  • 1998 MERCURY SABLE
  • 4 CYL
  • FWD
  • 165,435 MILES
Will not start one minute it will and then the next it will not even crank up, but the lights and clock comes on
Friday, June 25th, 2010 AT 8:06 AM
Do below could be a fuel or spark problem that's if its cranking over and will not start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Friday, June 25th, 2010 AT 8:36 AM
