Engine cranks but does not start?
180,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
KENNETH BROOKS
Put a new starter on and coil. The truck started and ran for 2 days. Now it just cranks but will not start.
Oct 25, 2023 at 4:23 AM
  • 110,248 POSTS
In most cases, a crank no-start condition is either caused by a loss of fuel or an ignition spark at the plugs. We need to determine which is missing.
Here is what I need you to do. See if the engine starts if you use starting fluid. If it does and then stalls, we know it is a fuel-related issue. If there is no change, then we need to check for spark at the spark plugs.
Here is a link that explains how to check:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Also, if you want to check for codes, you don't need a scan tool.
Here is a link that explains how it's done:
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
Let me know what you find.
Oct 25, 2023 at 12:42 PM
