1994 Ford F-150 Engine Turns over but will not start
TWATSON1
  • 1994 FORD F-150
  • V8
  • 19,500 MILES
Tested ignition coil, tested wire and connections have the right voltage, but still no start? My next task is to replace the pickup coil in the distributor cap. (?), Could there be any place else I should check
Thursday, June 10th, 2010 AT 2:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Are you certain it is a spark issue? Have you tested the fuel pressure and cylinder compression?
Thursday, June 10th, 2010 AT 11:37 PM
TWATSON1
I have not checked those items out yet, had two mechanics look at it and both says its an electrical problem, > it started after I plugged in a bad power inverter, through the power station, which caused smoke from the fuse panel area but all fuses are good and found no melted wires, they think it cause a short. All fuses inside and outside are good, I have power from the battery > all the way to the ignition coil wire > ignition coil itself down to the pickup coil wire. Even have power there, thats why the told me to change the pickup coil. But I will take note and check my book on what you stated to check. I resend msg with pictures here shortly.
Friday, June 11th, 2010 AT 9:42 AM
TWATSON1
Just checked back with another mechanic, he stated he did check fuel pressure and other you stated, it is getting fuel, it is getting compression, but he states no spark at all. > Continuance of previous msg. Tks.
Friday, June 11th, 2010 AT 9:56 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Ok if you have replaced the pick up coil and the plug wires tested good also then could be the PCM not sending signal to the coil in the first place
Friday, June 11th, 2010 AT 2:18 PM
