Engine shut off while idling it cranks but will not start?
TI2GER88
But now the charger is not plugged in and the car still will not start
Wednesday, August 12th, 2020 AT 1:23 PM (Merged)
TI2GER88
Also Tried to disconnect the charger all together and still will not start and all the fuses are fine as well
  • 52,797 POSTS
Did you test then with a test light? If they are good, ahve the fuel pressure and spark checked if both are missing it may have taken out the pcm.
DAREMT14040
  • 2005 FORD ESCAPE
  • 101,000 MILES
I was driving the other night and all of a sudden the engine was revving, jumping up to 3RPM. I pulled into a parking lot and put the car in park which was followed with a noise similar to dropping a bunch of change on the ground. I put the car in drive to move it into a parking space and again the engine revved without me pushing on the gas pedal. I figured if I turned the car off maybe it would somehow reset itself. Not. It would not start. It turns over but not starting right away, only when I push the gas pedal all the way down for a good 5 mins. The car will start but rev up to around 3RPM then quickly drops and stalls. All the fluids are full, no smell, and looks the way they should. Battery was tested and is ok. No dashboard warning lights come on. My dad has a cheap computer and when we read it, no codes were found. I added fuel injection cleaner which didn't help. I am not driving the car because I don't want to get stranded. What is going on with it?
HONDATECH1983
  • 109 POSTS
Check the throttle cable and the throttle body air intake plate to make sure they're not sticking. Also make sure the air intake tube/boot iisnt torn and creating an air leak past the mass air flow sensor. Make sure the mass air flow sensor doesn't have any trash surrounding it causing it to not read properly.
JIMMIE1231
  • 2005 FORD ESCAPE
  • 6 CYL
  • 4WD
  • 100,135 MILES
I have a 2005 Ford Escape. The check engine light came on and a little while later while driving on the highway it stalled and refused to start. I came back in the daylight to look at it and the engine will start but dies after a few seconds. I was told that it was a bad Idle Air Control valve but I replaced it and it still will start and run for a few seconds before dying again. When it does start its really rough and wont idle. It will not stay running even when feathering the throttle. It will not rev over 2000 rpm. Hope you can help. Thanks
Jim Smith
  • 31,937 POSTS
Hi there,
With the check light on, you will have a set fault code lodged in the ECU, have a scan done to read this code, post the results here for more assistance.
Mark (mhpautos)
CHARLIEWHOP
  • 2005 FORD ESCAPE
  • 3.0L
  • 6 CYL
  • 100,000 MILES
My alternator went out I replaced it with brand new one. Reset the inertia switch checked all the fuses still nothing. It cranks but does not start.
Wednesday, August 12th, 2020 AT 1:24 PM (Merged)
  • 52,797 POSTS
Good afternoon,
Can you hear the fuel pump run?
Is the security or theft light on?
Does the tachometer move up a little while cranking?
SEVAG P
  • 405 POSTS
Hello thanks for using 2CarPros.
The problem can be stucked alarm system, no ignition or no fuel supply, injection.
to narrow our problem first step read the fault codes.
this is our guide for engine does not start:
perform ignition spark test.
check fuel supply.
https://www.youtube.com/watch?v=dCjmRL3p4Cs
let us know what happens with you.
thank you.
CORKY88
  • 15 POSTS
  • 2006 FORD ESCAPE
  • 2.3L
  • AWD
  • 76,000 MILES
The motor turns over, but it does not start. I check the timing chain and it is good, the cam is turning over, the crank is tuning, the pistons are moving, but I am not getting compression at all. So what should check now? I will say the motor is tuning over like the timing chain was broke. Would the timing not right cause the motor not have compression?
Wednesday, August 12th, 2020 AT 1:30 PM (Merged)
HMAC300
  • 48,601 POSTS
How do you know you don't have compression? Did you use a compression gauge? S for codes and check fuel pressure with a gauge. Auto parts rent gauge
CORKY88
  • 15 POSTS
Yes I checked it with a compression gauge and yes I check the fuel pressure.I know if I didnt have fuel that it would not start, but that would not stop the no compression I have, so what else could stop the no compression?
HMAC300
  • 48,601 POSTS
If the timing chain/belt is not in time could be one thing, a blown head gasket another as well as piston damage for no compression what are your readings
CORKY88
  • 15 POSTS
The readings for the compression is 0 on all 4cly.
HMAC300
  • 48,601 POSTS
Then recheck your timing it probably jumped or broke a tensioner and bent valves.
CORKY88
  • 15 POSTS
Ok sure will thinks
