2001 Ford Escape engine stalls while driving
171,000 MILES • 6 CYL • FWD • AUTOMATIC
RICCLEE1
this truck has 171,000 miles and has been running good till today. while driving on the highway,the truck stalled while driving and i had to pull over to the shoulder.several hours later i restarted the truck and drove it about 100 yards and it stalled again,please help with a solution!
Jul 17, 2010 at 3:03 PM
  • 75,988 POSTS
If it refuses to start don't wait for nothing- do below to find out if its fuel or spark problem that's causing it not to start-something has to give.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jul 17, 2010 at 3:07 PM
