2001 Ford Escape Operation problems
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARTESC
I have a 2001 V6 Ford Escape. When I was stopped, and would push the accelerator to go, the car would sputter like it was going to stall and wasn't getting any gas. Sometimes it would finally go, other times it would stall out. What the problem?.
Oct 8, 2008 at 2:00 AM
2CARPRO JACK
  • 11,533 POSTS
Need to have it scanned for codes.Im guessing the check engine light is on. If not still have it scanned, the PCM probably stored something in freeze frame/failure records. There are simply too many possibilities to guess
Oct 8, 2008 at 5:46 AM
MARTESC
[quote:5f97abd48a="2CarPro Jack"]Need to have it scanned for codes.Im guessing the check engine light is on. If not still have it scanned, the PCM probably stored something in freeze frame/failure records. There are simply too many possibilities to guess[/quote:5f97abd48a]
I did the computer check and not errors was shown.
Oct 8, 2008 at 9:49 AM
2CARPRO JACK
  • 11,533 POSTS
You did the scan? did you check freze frame/failure records? If so and it is an intermittent problem, you will have to check fuel pressure and spark quality. Might be a Mass Airflow Meter , but without any codes and it being intermittent, it would be strictly guess work
Oct 8, 2008 at 10:00 AM
