will not start, I replaced fuel pump and the fuel injectors?
2013 HYUNDAI ELANTRA
85,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
FRANKEE3
I replaced the fuel pump and the fuel injectors.
May 6, 2023 at 4:51 AM
  • 110,240 POSTS
In most cases, a crank with no start is the result of either a loss of fuel (you mentioned repairs) or an ignition spark to the plugs.
Here is what I need you to do: See if the engine starts using starting fluid. If it does and then stalls, we know we still have a fuel-related issue. If there is no change, we need to check for spark to the plugs.
Here is a link that explains how to check:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this and let me know the results. Also, let me know if you have other questions.
May 6, 2023 at 12:56 PM
