Will no go into second or reverse
190,000 MILES
GREGORY KRAHN
My vehicle all of a sudden wont shift into second gear, or into reverse. It'll go into second if I'm going down a hill. A whirring noise started as well when I'm in park and reverse. Not drive, 1, 2, or 3. Any ideas?
Sep 23, 2019 at 1:22 PM
STEVE W.
  • 15,390 POSTS
Welcome to 2CarPros. That description sounds like the sun shell in the transmission has sheared it's teeth. Common failure in the 4L60E unfortunately. Repair is a rebuild of the transmission and replacement of the sun shell. There are a couple options for better shells for that transmission if the rest of the vehicle is in good enough shape to justify the cost.
Sep 23, 2019 at 1:38 PM
