Rear wheel spins in drive or reverse when at an idle
6 CYL • 2WD • AUTOMATIC
CLEONARD54
Got stuck the other day and when I put my truck in drive, took my foot off the brake and without giving it any gas, one rear wheel started to spin. The idle doesn't sound fast or out of control so I just let it do it's thing while turning the wheel back and forth and it was spinning enough to actually work me out of the slush pile. Why does just one rear wheel spin when it's in drive and reverse and is this something else I need to add to my large list of repairs this vehicle needs.
Mar 15, 2014 at 4:49 AM
CJ MEDEVAC
  • 11,000 POSTS
THIS IS HOW A STANDARD DIFFERENTIAL WORKS----ON THE FRONT OR REAR
AN UPGRADED VERSION OF A DIFFERENTIAL IS A "LIMITED SLIP"---BOTH WHEELS PULL IN THE SAME DIRECTION, BUT THE WAY IT WORKS STILL ALLOWS YOU TO MAKE LEFT OR RIGHT TURNS WITHOUT DRAGGING A WHEEL .........COST IS MORE, AND USUALLY REQUIRES A LITTLE MORE SPECIAL MAINTENANCE ATTENTION
BOTH JEEPS I OWN NOW HAVE TRADITIONAL STANDARD DIFFERENTIALS.......1946.....1977
THE MEDIC
Mar 15, 2014 at 11:16 PM
KNOWLEDGE IS POWER
  • EXPERT
  • 1,136 POSTS
Having one wheel spin is normal unless you have a positive traction rear end.
Mar 16, 2014 at 2:40 AM
