Will not go in gear when at a complete stop
194,934 MILES • 3.8L • V6 • 2WD • AUTOMATIC
HEATHER ROBINSON
Early mornings when I start my van sometimes will go in reverse, but main issue is when I put it in drive from reverse it sounds like it is in neutral. Mainly when I stop at a stop sign it won't go in gear. It just raises the rpm's and then kicks hard into gear. But if I let it kick into gear on its on it takes up to five minutes. Very dangerous when I go to pull out of the store and it just randomly decides to not go in gear and I am stuck in the oncoming traffic and my two year old is with me. But if I drive it long enough it will not do any of that and makes me look dumbfounded when I tell someone about it. It is almost like it needs to warm up first. But going up hills it does it and rolls backwards, then kicks in gear! When I start to push on the brake I feel a kick, if I feel that kick I know when I stop it will go. If no kick. It does not go. Please help. It is my only transportation for my son to get back and forth to physical therapy and occupational therapy and his brain surgeon.
Jun 22, 2017 at 3:41 AM
STEVE W.
  • 15,394 POSTS
Check the transmission fluid level. Low fluid can cause this issue.
Jun 22, 2017 at 3:59 AM
HEATHER ROBINSON
I have and it has the requirements it needs.
Jun 22, 2017 at 8:19 AM
STEVE W.
  • 15,394 POSTS
Okay, do you know if the transmission has ever been serviced? It sounds like either a sticking solenoid that frees up once warmed up or the filter is loose. A transmission shop could do a few tests and see if it is pressure related or filter.
Jun 22, 2017 at 4:03 PM
HEATHER ROBINSON
No I do not think it has. I need to find a good mechanic in my area.
Jun 22, 2017 at 11:44 PM
  • 55,658 POSTS
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Jun 26, 2017 at 4:08 AM
