Tried starter fluid no start issue?
253,814 MILES • 3.0L • V6 • 2WD • AUTOMATIC
JOHNNYGONZ41
Won't start. Tried starter fluid and almost did. I believe there isn't any flow of fuel. Replaced fuel filter but I guess there's no power to it.
Nov 8, 2024 at 2:20 AM
  • 55,711 POSTS
If it was fuel related it would have started on starting fluid. Can I ask how the engine sounds while cranking over? If the timing belt has jumped time the engine will act like it wants to start but won't. Here is a video for you to go over to help you see what's going on:.
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t=29s
Can you please shoot a quick video with your phone so I can hear the engine cranking? That way I can tell for sure what's going on. You can upload it here with your response.
Nov 8, 2024 at 8:39 AM
