Window will roll down but not back up
139,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
BLAZE45X
1999 Ford F150 power windows. Passenger side went down but will not go back up.
The flow I found here (http://www.justanswer.com/ford/2z0ik-1999-f150-passenger-side-power-window-goes-down-will.html) says to replace the drivers side switch, then if it still doesn't work to replace the passenger side switch.
The motor is still getting power because it will roll it down.
There has to be a better way to test them instead of just buying the parts and replacing them?
Thanks!
May 5, 2014 at 11:42 AM
CARADIODOC
  • 34,415 POSTS
There is a less expensive way but it's definitely not easier. The issue is there are actually four switches involved in a passenger window. Two are in the driver's switch assembly and two are in the passenger's switch. All four of them make contact, or a complete circuit, to ground when they're released. When one of the switches is activated, one of its switches breaks the circuit to ground first, then makes the circuit to 12 volts. The other switch remains connected to ground. It's those three that remain grounded that could have a bad contact along with the one that is activated. In other words, regardless of which switch is activated which way, all current has to flow through four sets of contacts, . . . two in each switch.
You would have to use a voltmeter or test light to see how far you have voltage and where you lose it, and you'd have to follow the path in the wiring diagram to get the right wire colors. To really complicate it, to be accurate, any such testing has to be done with everything connected so current is trying to flow. If no current is trying to flow, a burned connection can be overlooked when the voltmeter picks up a voltage that sneaks through due to needing almost no current.
If you have the wiring diagram, a test light or voltmeter, and the time, that's fine, but when we have to charge for our time, it's much faster to just plug in a good used switch and try it. There's plenty of them in the salvage yards, so you don't have to buy new ones.
You may also be able to determine which switch is causing the problem by measuring the voltages on the various wires. One will have 12 volts all the time. Ignore that one. Of the other four wires on that switch, only one will get 12 volts when it is activated. If you activate the switch and find 12 volts on none of those four wires, or two of those wires, that's the bad switch.
May 5, 2014 at 12:33 PM
BLAZE45X
Outside of the switches and motor (and of course the wiring) there isn't any other relays/regulators that I need to worry about?
Thank you for your help.
May 6, 2014 at 4:14 AM
CARADIODOC
  • 34,415 POSTS
The insane engineers have hung computers onto every possible circuit and system that never needed computers before, but the windows on your truck do not involve a computer, . . . yet. I don't recall there being any relays either. That is an unnecessary attempt at complicating the system that's left to the GM designers.
May 6, 2014 at 9:04 AM
