Will not start. loose ignition lock
V6
14LOTUS
I have a 1997 Ford Taurus. Yesterday I went to start my car. Lights and radio came on but it won't turn over and start made no noises at all. My ignition lock cylinder was very loose when turning the key and when I tried to turn it off the lights stayed on. Tried replacing the lock cylinder today but it did not make a difference. Any idea of what it could be? Thank you.
Aug 8, 2014 at 8:30 AM
HMAC300
  • 48,601 POSTS
check fuse 8 inside car and checkbattery for condition including load test. if you have any fusible links on relay check those as well
Aug 8, 2014 at 11:32 PM
HMAC300
  • 48,601 POSTS
might be a bad switch as well
Aug 8, 2014 at 11:34 PM
JUSTDON
  • 161 POSTS
Same thing happened to my 97 taurus. In my case, the plastic slide inside the column head broke. Lock cylinder does nothing. I had to un-bolt the ignition switch (under the steering column) and start the car by sliding the pin up. I was glad that it didn't lock my steering wheel.
May be your problem as well.
Sep 12, 2014 at 7:54 AM
MASAMICOWBOY
Justdon, what repair was needed? Or did you have to replace the whole steering column?
Sep 24, 2023 at 12:57 PM
  • 110,251 POSTS
I'm sorry, but that is a post from 2014 and there was never a resolution included. However, if you have the same vehicle with the same type of issue, I would be happy to help.
Let me know exactly what is happening.
Sep 26, 2023 at 1:24 PM
MASAMICOWBOY
Jacobsandnickolas, I'm having the same issue currently on a 2001 model Taurus. I'm just gonna replace the steering column (front section , not the section going through the fire wall) It's either the plastic ring as mentioned or the nylon plastic linkage that connects to the switch. I haven't stuck a screwdriver up the slot where the switch sits yet, but if it is loose then it's the linkage.
I can either just buy the new column for $100+/- (plus shipping) and install it myself or pay to have the issue diagnosed for $150, have the part bought and then pay the mechanic's going rate.
The column is pretty closed in with a metal casing and I'm not even going to begin to take it apart. I've seen the exploded diagram, it's pretty involved.
Thank you for getting back to me. I just did independent research.
Daddy DIY on YouTube, has a video on it.
Sep 28, 2023 at 11:15 AM
  • 110,251 POSTS
Thanks for the update. What you plan to do is a good idea. If there is anything I can do to help, let me know.
Sep 29, 2023 at 2:29 PM
