Will not RUN
125,436 MILES
DOCIVY1
My friends caravan 96 had sat for 4 years. I checked it and replaced the fuel pump. It ran but with limited power. checked plugs they were getting wet. Replaced them and the coil (4 was not firing) then it would'nt start at all. Replaced the computer and got fire to the plugs then I replaced all the injecters and the upper intake gaskets. I have fuel line preasure, it tries to start but then just turns over. But stater fuel will keep it running. Any ideas?
May 20, 2013 at 10:56 AM
4 years???? it needs the tank dropped, flushed out with the lines and evey fluid change in the car before starting.
roy
May 20, 2013 at 11:03 AM
DOCIVY1
I did drop the tank and clean it out but not the fuel line.
May 20, 2013 at 1:26 PM
