Will not idle
186,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
ZECHARIAH PRICE
Just replaced my knock sensors. While doing the job, replaced valve cover gaskets and intake manifold gaskets. Battery was disconnected for about 2 days. After completing the job, the car will not stay idling. Will start right up and idle at a very very low rpm, or it will shut off straight away. If I keep my foot on the gas pedal it will stay idling. I can drive the car if I just hold the gas and brake at a stop. Tried to "relearn" the idle with no luck.
Aug 11, 2020 at 10:34 AM
  • 110,248 POSTS
Have you checked for engine vacuum leaks? Since you had the intake off, there is a chance you missed a hose or one was broken. Here is a link that will help locate a leak if one exists:
Also, take a look through this link and see if anything helps:
https://www.2carpros.com/articles/stall-at-idle
Let me know what you find.
Aug 11, 2020 at 11:51 AM
