2002 Toyota Camry Won't Idle
JEREMYK
I recently bought a 2002 Camry 5-speed.I disconnected the battery to clean the terminals and when I reconnected the battery and started the car,it wouldnt idle.In a few days,the problem cleared up and the car ran fine.Today I removed the factory muffler and it wont idle again.
Jul 12, 2007 at 10:53 AM
  • 75,988 POSTS
[quote:e939d6931e="JeremyK"]I recently bought a 2002 Camry 5-speed.I disconnected the battery to clean the terminals and when I reconnected the battery and started the car,it wouldnt idle.In a few days,the problem cleared up and the car ran fine.Today I removed the factory muffler and it wont idle again.[/quote:e939d6931e]
Probably it needs an other relearning, this time it has to do with the oxygen sensors and exhaust flow.
Jul 14, 2007 at 5:07 PM
Suggested Repair
Allow the engine control system to relearn idle after the battery disconnect and muffler removal. The no-idle condition may be related to oxygen-sensor feedback and the change in exhaust flow.
Conversation Summary
A 2002 Toyota Camry 5-speed would not idle after the battery was disconnected to clean the terminals, then returned to normal after a few days. After the factory muffler was removed, it would not idle again. The expert said it likely needs another relearn, this time involving the oxygen sensors and exhaust flow.
