Does it fire right back up after it stalls of does it have to set for a few hours before running again?
If it doesnt fire right back up check for fuel pressure, or spray starting fluid in the throttle body, if it fires up then it is a fuel problem and I would continue by checking for voltage at the fuel pump, if you have voltage but no fuel, at fuel rail replace the pump.
SPONSORED LINKS
Saturday, November 24th, 2007 AT 9:11 AM
