will not go out of low power mode
200,000 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
TRAVELCREW
  • 25 POSTS
replaced throttle body,throttle,wiring between the throttle and throttle body still will not rev up. We checked the voltage coming into the throttle body 5 volts.
Dec 30, 2019 at 10:38 AM
  • 110,248 POSTS
Have you checked the accelerator pedal position sensor? See pic 1. Also, have you checked the throttle position sensor?
The voltage you mention is correct. Here are descriptions of the two things I mentioned. Let me know if they have been replaced as well.
_______________________________
Accelerator Pedal Position (APP) Sensor
The APP sensor is mounted on the accelerator pedal assembly. The APP is actually 2 individual APP sensors within 1 housing. There are 2 separate signal, low reference, and 5-volt reference circuits. APP sensor 1 voltage increases as the accelerator pedal is depressed. APP sensor 2 voltage decreases as the accelerator pedal is depressed.
Throttle Body Assembly
The throttle body for the throttle actuator control (TAC) system is similar to a conventional throttle body with several exceptions. One exception being the use of a motor to control the throttle position instead of a mechanical cable. Another exception is the throttle position (TP) sensor. The TP sensor is mounted in the throttle body assembly. The TP sensor is 2 individual TP sensors within the throttle body assembly. Two separate signal, low reference, and 5-volt reference circuits are used to connect the TP sensors and the power-train control module (PCM). TP sensor 2 signal voltage increases as the throttle opens. TP sensor 1 signal voltage decreases as the throttle opens.
________________________________
Dec 31, 2019 at 3:57 PM
TRAVELCREW
  • 25 POSTS
Okay, we will check.
Dec 31, 2019 at 10:01 PM
TRAVELCREW
  • 25 POSTS
we ran test the voltage does not change.
Jan 1, 2020 at 8:37 AM
  • 110,248 POSTS
Are you referring to the TPS or APP sensor? If the TPS and nothing changes, suspect the APP and vice versa.
Let me know exactly what you did and results.
Take care and happy new year.
Jan 1, 2020 at 9:21 AM
TRAVELCREW
  • 25 POSTS
unplugged at throttle body tested voltage there was no change on any test.
Jan 1, 2020 at 9:34 AM
  • 110,248 POSTS
Okay, then we have to find where the break is. The first thing I would check is to see if the APP sensor is working. Determine if the voltage changes based on different pedal positions. If it doesn't, replace the APP. If it does, then we have a break between the pedal and the PCM or the PCM and the throttle position sensor.
Let me know if you have questions.
Jan 1, 2020 at 9:40 AM
TRAVELCREW
  • 25 POSTS
the throttle assembly is new.
Jan 1, 2020 at 9:43 AM
  • 110,248 POSTS
When you say throttle assembly, are you referring to the throttle body or the accelerator pedal position sensor in the vehicle above the gas pedal? If I understood correctly, I believe you replaced the throttle body which should have a net throttle position sensor (TPS).
Let me know. We'll figure it out one way or another. LOL
Jan 1, 2020 at 9:46 AM
TRAVELCREW
  • 25 POSTS
we replaced the throttle body and the gas pedal assembly. so should have new accelerator pedal position sensor?
Jan 1, 2020 at 9:53 AM
  • 110,248 POSTS
Okay. Then we need to start checking. Here is a list of how the TAC system works. Let me know where you would like to start and I start looking through diagnostic flow charts and send them to you as well.
___________________________________________________
2007 Chevy Truck TrailBlazer 2WD L6-4.2L
Throttle Actuator Control (TAC) System Description
Vehicle Powertrain Management Computers and Control Systems Electronic Throttle Actuator Description and Operation Components Throttle Actuator Control (TAC) System Description
THROTTLE ACTUATOR CONTROL (TAC) SYSTEM DESCRIPTION
Throttle Actuator Control (TAC) Overview
The throttle actuator control (TAC) system uses vehicle electronics and components to calculate and control the position of the throttle blade. This eliminates the need for a mechanical cable attachment from the accelerator pedal to the throttle body. This system also performs the cruise control functions as well.
The TAC system components include, but are not limited to the following:
* The accelerator pedal position (APP) sensors
* The throttle body
* The powertrain control module (PCM)
Each of these components interface together to ensure accurate calculations and control of the throttle position (TP).
The throttle body for the throttle actuator control (TAC) system is similar to a conventional throttle body with several exceptions. One exception being the use of a motor to control the throttle position instead of a mechanical cable. Another exception is the throttle position (TP) sensor. The TP sensor is mounted in the throttle body assembly. The TP sensor is 2 individual TP sensors within the throttle body assembly. Two separate signal, low reference, and 5-volt reference circuits are used to connect the TP sensors and the powertrain control module (PCM). TP sensor 2 signal voltage increases as the throttle opens. TP sensor 1 signal voltage decreases as the throttle opens.
Modes of Operation
Battery Saver Mode
If the powertrain control module (PCM) detects the ignition ON for 10 seconds without the engine running, the PCM will allow the throttle blade to return to the default position. This removes the draw that is present while holding the throttle blade at the calculated idle position.
Reduced Engine Power Mode
When the PCM detects a problem with the throttle actuator control (TAC) system the PCM enters one of the following Reduced Engine Power Modes:
* Acceleration Limiting-The control module will continue to use the accelerator pedal for throttle control, however the vehicle acceleration is limited.
* Limited Throttle Mode-The control module will continue to use the accelerator pedal for throttle control, however the maximum throttle opening is limited.
* Throttle Default Mode-The control module will turn off the throttle actuator.
* Forced Idle Mode-The control module will perform the following actions:
- Limit engine speed to idle by positioning throttle position, or by controlling fuel and spark if throttle is turned off.
- Ignore accelerator pedal input.
* Engine Shutdown Mode-The control module will disable fuel and de-energize the throttle actuator.
Jan 1, 2020 at 2:10 PM
TRAVELCREW
  • 25 POSTS
We would like to check the wiring from PCM to throttle body and gas pedal .
Jan 1, 2020 at 9:03 PM
TRAVELCREW
  • 25 POSTS
we replaced the electric part of key switch. ran fine for about one minute find then back to low power mode.
Jan 2, 2020 at 9:35 AM
TRAVELCREW
  • 25 POSTS
I think the Throttle Default Mode would be a good place to start.
Jan 2, 2020 at 11:14 AM
  • 110,248 POSTS
I have to ask, have you checked for diagnostic trouble codes? I am finding quite a few codes related to the TPS. If you have, let me know what they are.
Jan 2, 2020 at 2:19 PM
TRAVELCREW
  • 25 POSTS
Thursday a friend stopped with his scanner codes P1516,andP1682 came up so we replaced the switch
Jan 3, 2020 at 7:31 AM
  • 110,248 POSTS
What switch? Was it the ignition switch? That is the only one I can think of that can be associated with the one code.
Also, the 1516 is specific to the throttle actuator control system. With this code, there should be information stored in "Freeze Frame" data. If the scanner can read that, check to see what was happening when the code was set.
Now the P1682 is related to either related to a short to ground or an open in the power-train relay, or it is an open or high resistance in the ignition main relay. See pic 1.
Did the replacement of the switch take care of the problem?
Jan 3, 2020 at 2:27 PM
TRAVELCREW
  • 25 POSTS
scanner is not able to read everything. we replace ignition switch ran fine for about one minute then back into low power mode. I guess I am a little confuse with the picture it does not show a relay.
Jan 3, 2020 at 9:02 PM
  • 110,248 POSTS
I attached the only pics I have. It is of the power distribution box under the hood, Let me know if it helps.
Jan 4, 2020 at 10:31 AM
TRAVELCREW
  • 25 POSTS
replaced both relays and still same problem.
Jan 5, 2020 at 8:31 AM
TRAVELCREW
  • 25 POSTS
will not rev up over 1400.
Jan 5, 2020 at 8:42 AM
  • 110,248 POSTS
The codes indicated a short or open to the relay. Did you check for that as an issue? Here are the diagnostics. The attached pics correlate with the directions.
P1682
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection P Code Charts P1682
P1682
DTC P1682
Diagnostic Instructions
Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure. See: Vehicle > Initial Inspection and Diagnostic Overview
Review Strategy Based Diagnosis for an overview of the diagnostic approach. See: Vehicle > Initial Inspection and Diagnostic Overview
Diagnostic Procedure Instructions provides an overview of each diagnostic category. See: Vehicle > Initial Inspection and Diagnostic Overview
DTC Descriptor
DTC P1682: Ignition 1 Switch Circuit 2
Diagnostic Fault Information
pic 1
Typical Scan Tool Data
EC Ignition Relay Feedback Circuit
pic 2
Ignition 1 Signal
pic 3
Circuit/System Description
There are two ignition 1 voltage circuits supplied to the engine control module (ECM). The first ignition 1 voltage circuit is provided by the powertrain relay through a fuse. This ignition 1 voltage circuit supplies power to all the internal ECM circuits associated with the throttle actuator control (TAC) operation. The ignition main relay provides the second ignition 1 voltage circuit to the ECM through a fuse. This ignition 1 voltage provides power to other internal ECM circuits, except those associated with TAC operation. The ECM continuously monitors the voltage level difference between the 2 circuits.
Conditions for Running the DTC
The ignition is in the Unlock/Accessory, Run, or Crank position.
The powertrain relay is commanded ON.
DTC P1682 runs continuously when the above conditions are met.
Conditions for Setting the DTC
The ignition 1 voltage of the ignition main relay is more than 3 volts different than the ignition 1 voltage of the powertrain relay for more than 2 seconds.
Action Taken When the DTC Sets
DTC P1682 is a Type A DTC.
Engine may operate in a reduced engine power mode.
Conditions for Clearing the DTC
Reference Information
Schematic Reference
Engine Controls Schematics See: Powertrain Management > Electrical
Electrical Center Identification Views See: Fuse > Application and ID
Connector End View Reference
Powertrain Control Module Connector End Views See: Engine Control Module > Connector Views
Powertrain Control Module Description See: Engine Control Module > Components > Powertrain Control Module Description
Electrical Information Reference
Circuit Testing See: Vehicle > Component Tests and General Diagnostics > Circuit Testing
Connector Repairs See: Vehicle > Component Tests and General Diagnostics > Connector Repairs
Wiring Repairs See: Vehicle > Component Tests and General Diagnostics > Wiring Repairs
DTC Type Reference
Powertrain Diagnostic Trouble Code (DTC) Type Definitions
Scan Tool Reference
Scan Tool Data List for scan tool information See: Computers and Control Systems > Scan Tool Testing and Procedures > Scan Tool Data List
Circuit/System Verification
1. If DTCs P0685, P0689, or P0690 are set, diagnose those DTCs first.
2. Ignition ON, engine OFF, observe the Ignition 1 voltage signal and the EC Ignition Relay Feedback signal parameters on the scan tool. Both parameter values should display no more than 3 volts difference between the 2 parameters.
3. Ignition OFF, observe the ignition 1 voltage signal parameter on the scan tool. The parameter value should be 0 volts before the ECM powers down.
Circuit/System Testing
1. Ignition OFF, disconnect the powertrain relay.
2. Ignition ON, verify that a test lamp does not illuminate between the powertrain relay controlled output circuit terminal and ground.
- If the test lamp illuminates, test the powertrain relay controlled output circuit for a short to voltage.
3. Ignition OFF, verify that a test lamp illuminates between the powertrain relay coil voltage supply circuit terminal and ground.
- If the test lamp does not illuminate, test the powertrain relay coil voltage supply circuit for a short to ground or an open/high resistance.
4. Verify that a test lamp illuminates between the powertrain relay switch voltage supply circuit terminal and ground.
- If the test lamp does not illuminate, test the powertrain relay switch voltage supply circuit for an open/high resistance.
5. Disconnect the ECM.
6. Ignition ON, verify that a test lamp illuminates between ECM connector terminal 19 X1 and ground.
- If the test lamp does not illuminate, test the ignition 1 relay controlled output circuit for a short to ground or open/high resistance. If the circuit tests normal and its fuse is open, replace the ECM.
7. Ignition OFF, connect the harness connector at the ECM.
8. Ignition ON, connect a jumper wire between the powertrain relay voltage supply circuit terminal and the powertrain relay controlled output circuit terminal. Verify the EC Ignition Relay Feedback parameter indicates battery positive voltage.
- If not the specified value, test the powertrain relay controlled output circuit for a short to ground or an open/high resistance. If the circuit tests normal and its fuse is open, replace the ECM.
9. If all circuits test normal, replace the powertrain relay.
Repair Instructions
Perform the Diagnostic Repair Verification after completing the diagnostic procedure. See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests
Relay Replacement See: Vehicle > Removal and Replacement
Control Module References for ECM replacement, setup, and programming See: Vehicle > Programming and Relearning > Control Module References
__________________________________________________________________
P1516
Vehicle ALL Diagnostic Trouble Codes ( DTC ) Testing and Inspection P Code Charts P1516
P1516
DTC P1516
Circuit Description
The commanded throttle position is compared to the actual throttle position based on accelerator pedal position (APP) and possibly other limiting factors. Both values should be within a calibrated range of each other. The powertrain control module (PCM) continuously monitors the commanded and actual throttle positions. This DTC sets if the values are greater than the calibrated range.
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
* The ignition is ON.
* The ignition voltage is greater than 8 volts.
* The system is not in the battery save mode.
* The engine is running.
* DTC P0068 is not set.
* DTC P1516 runs continuously when the above conditions are met.
* The difference between the predicted and the actual throttle position is more than a calibrated amount.
* The above condition is present for more than 0.5 second.
* The control module illuminates the malfunction indicator lamp (MIL) when the diagnostic runs and fails.
* The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Freeze Frame and/or the Failure Records.
* The control module commands the TAC system to operate in the Reduced Engine Power mode.
* A message center or an indicator displays Reduced Engine Power.
* Under certain conditions the control module commands the engine OFF.
Conditions for Clearing the MIL/DTC
* The PCM turns OFF the MIL after 3 consecutive drive trips that the diagnostic runs and passes.
* A History DTC clears after 40 consecutive warm-up cycles in which there are no failures reported of this diagnostic or any other emission related diagnostic.
* The scan tool clears the MIL/DTC.
Diagnostic Aids
The throttle valve is spring loaded to a slightly open position. The throttle valve should be open approximately 20 percent. This is referred to as the rest position. The throttle valve should not be completely closed nor should they be open any more than the specified amount. The throttle valve should move open and to the closed position without binding under the normal spring pressure. The throttle should NOT be free to move open or closed WITHOUT spring pressure. Replace the throttle body if any of these conditions are found.
Important: Operating the throttle blade with the Throttle Blade Control function of the scan tool may cause additional DTCs to set. Do not attempt to diagnose DTCs set during this function.
The scan tool has the ability to operate the throttle control system using Special Functions. Actuate the throttle valve using the throttle blade control function located in the Throttle Actuator Control (TAC) System menu. This function will operate the throttle valve through the entire range in order to determine if the throttle body and system operate correctly.
Check for the following conditions:
* Use the J35616 Connector Test Adapter Kit for any test that requires probing the PCM harness connector or a component harness connector.
* Poor connections at the PCM or at the component-Inspect the harness connectors for a poor terminal to wire connection. Refer to Testing for Intermittent Conditions and Poor Connections for the proper procedure. See: Vehicle > Component Tests and General Diagnostics
* For intermittents, refer to Intermittent Conditions. See: Computers and Control Systems > Initial Inspection and Diagnostic Overview > Intermittent Conditions
Test Description
Step 1 - Step 8
pic 4
Step 9 - Step 16
pic 5
Step 17 - Step 27
pic 6
The numbers below refer to the step numbers on the diagnostic table.
8. The throttle valve is spring loaded in a slightly open position and should move in either direction without binding. The throttle valve should always be under spring pressure.
11. When the ignition is turned ON, the PCM operates the throttle control motor to verify the integrity of the system prior to start-up. This can be seen by the momentary flash of the test lamp as the ignition is turned ON.
___________________
Let me know what you find.
Jan 5, 2020 at 11:04 AM
TRAVELCREW
  • 25 POSTS
Okay, thanks.
Jan 5, 2020 at 11:11 AM
  • 110,248 POSTS
If you get a chance, let me know if that helps or if you have other questions.
Jan 5, 2020 at 1:10 PM
TRAVELCREW
  • 25 POSTS
we got a different scanner and hooked up. can not read ignition voltage and nothing on gas pedal. did you have any ideas?
Jan 9, 2020 at 10:24 AM
  • 110,248 POSTS
You did check the relay, correct? It was good? No blown fuses? If that is the case, you have an open between the relay and the switch.
Jan 9, 2020 at 11:28 AM
TRAVELCREW
  • 25 POSTS
we replaced both relays.
Jan 9, 2020 at 9:11 PM
  • 110,248 POSTS
I understand. However, did you check for power at the relays? The code indicated there was a problem prior to the relay itself. If there is a problem to the relay, a new relay won't fix a problem.
Jan 10, 2020 at 7:41 AM
TRAVELCREW
  • 25 POSTS
no will test that next. if no power where do we look next?
Jan 10, 2020 at 9:37 AM
  • 110,248 POSTS
At that point, it becomes a wire tracing issue. You have to follow the power supply wire back to locate where power is lost. It can be a nightmare.
Jan 10, 2020 at 11:20 AM
TRAVELCREW
  • 25 POSTS
thanks , we have worked on this a little everyday for the past month it is past the nightmare stage.
Jan 10, 2020 at 8:09 PM
  • 110,248 POSTS
LOL. I totally understand. And thanks. I needed a laugh.
Jan 11, 2020 at 12:35 PM
TRAVELCREW
  • 25 POSTS
we worked on the problem child today. checked every wire from throttle body back to the computer checked okay. did the same on the gas pedal everything checked okay.
Jan 12, 2020 at 7:14 AM
  • 110,248 POSTS
At this point, if everything checked out as far as the specs indicated in the aforementioned link, we have to assume it is a computer related issue. You really need to have that checked. I'm not sure how to direct you with that and be accurate. There is no specific test I have.
You may have to remove it and have it checked at a dealer.
I hope you understand. Everything checks good as far as the diagnostics. It must be something before that causing a problem.
Jan 12, 2020 at 11:43 AM
TRAVELCREW
  • 25 POSTS
Yes and a new computer will be here today.
Jan 12, 2020 at 6:03 PM
TRAVELCREW
  • 25 POSTS
replaced computer now new code is crank sensor cannot detect.
Jan 13, 2020 at 9:42 AM
  • 110,248 POSTS
What code is it? I assume, there is no spark, correct?
Jan 13, 2020 at 11:17 AM
TRAVELCREW
  • 25 POSTS
It started up, still I low power mode. new code was cannot detect crank sensor.
Jan 13, 2020 at 7:39 PM
  • 110,248 POSTS
Have you checked the sensor? Also, if you take a multi meter, there should be a signal wire and a low reference wire. Check if there is a signal from the sensor. See the attached pic. I circled pin A. That is the low reference pin. B is the signal from the sensor.
Let me know what is found.
Jan 14, 2020 at 9:22 AM
TRAVELCREW
  • 25 POSTS
thanks, we will try it tomorrow and see what it does.
Jan 14, 2020 at 10:57 AM
  • 110,248 POSTS
I feel really bad that I don't seem to be getting you through this. It makes it a lot harder not being there. See if you are getting anything at the crank sensor. Also, confirm for me if it is a 2 or 3 wire sensor.
Jan 14, 2020 at 12:19 PM
