Oct 28, 2026 at 5:47 AM
Why won't my electric locks work?
Unplugging it might help in diagnostics but may not help with the rest. It could be the BCM itself, but a bad BCM doesn't usually blow fuses, that is usually from excess current draw. However with a conversion build things can become a rats nest real quick.
So with that being said... it may not be a bad BCM. I hope its not.. people with keyless entry just don';t know how convenient that is to have that working etc. Looks like i may have to get a automotive electrician to look at it for me. I really don't want to go down that road but it looks like i may have too. And like you said a bad BCM shouldn't be blowing a fuse at all. Is the BCM located in the B pillar of the van? I guess that would be hard to find out when it is a conversion van.
Oct 28, 2026 at 8:18 AM
Really depends on the conversion company. Some keep parts in stock locations, just behind a removable panel, others like to extend harnesses and relocate things. It can make it interesting.
Oct 28, 2026 at 10:12 AM
If the BCM is behind the driver's seat in the b pillar then i can get to that and have it rebuilt but if its under the dash then i am in a really tough spot. I cannot reach that at all. And those test you ask me to do.. None of them produced positive results. I went to each door and hear nothing. Just the click i hear or think i hear coming from the b pillar and the dash board. But when you go to each door and use the key on each door the door operates like normal. I know that by doing things that way you won't be using the wireless entry feature but. The locks unlock and lock that way. And i am going to order some 15 amp & 20 amp breaker fuses to see what happens. Some people even told me to stop using the key fob to set the alarm because i might blow a fuse some where else in the system before i can find the problems to fuse 4 and 5. Dunno if that is true or not but. I have been having this wireless issue since 2023 too etc
Oct 30, 2026 at 11:16 PM
Quick question: Could i just put in a new after market wireless entry to my van and by pass the original one that came with the van at all? Would that get the dome lights and locks to work you think?
Nov 1, 2026 at 8:45 PM
I would check the lock actuators, if one is shorted it can cause the fuses to blow.
Nov 2, 2026 at 7:27 AM
The BCM likely isn't the issue, I have a feeling it's either one of the door harnesses or an actuator that is shorting, I had hoped that the testing would point the way a lot more. The problem is that on the vans you have a one shot system, locking locks all doors, so if say the right door has the problem you cannot isolate it easily. What you might do to check that would be to pull the accordion boots back on each door and look for broken or chafed wires. The flexing causes them to break and rub.
Nov 2, 2026 at 10:18 AM
Ok i will give that a try..i will check the accordion boots back on each door. Those boots are pulled kinda tight on there too. I tried wiggling it and they would not move at all. I think will go ahead and buy a lock actuator(s) too like STRAILER said too. Because i remember now that before all this happened the driver's do lock actuator started acting up first. I would push the buttons and all the other locks would pop up and lock but i had to push the button a few times just for the driver's door to lock and unlock.
Nov 5, 2026 at 12:02 AM
That would be an indication of a problem. I would check the wiring first though, no reason to replace the actuator if it's a broken pr shorted wire causing the problem.
Nov 5, 2026 at 12:03 PM
Ok.. i will check that. In the mean time take a look at what i found on the net. And yes my van came from the factory with wireless entry... and what do they mean by its a B type system... Is any of that true in the 2 pictures? Because if it is, now i know what 2 wires to look for.
Nov 12, 2026 at 3:04 PM
Doesn't make any real difference. I already figured that it had a fob from the factory. From all you have posted and how it is blowing a higher amp fuse says it isn't the module itself, all those do is act as a wireless switch. If it was a bad module it would likely have turned into a crispy item whenever you hit the button. Instead it still sounds like a bad actuator or a harness short, but the only real way to find that is to go hunting.
Nov 12, 2026 at 3:13 PM
I was hoping you wasn't going to say that (go hunting lol) but looks like i will have to get an automotive electrician. i can't get to myself (wheelchair etc). The only thing i can half way get to is the actuator etc
Nov 12, 2026 at 6:53 PM
Yep, sometimes that is best. Please let us know what they find.
Nov 15, 2026 at 7:10 AM
Will do.. hopefully soon I'll let you and Steve W. know
Nov 15, 2026 at 5:05 PM
Perfect.
Nov 17, 2026 at 7:59 AM
🔧 Tools & Auto Repair Parts
Find automotive tools, diagnostic equipment, and replacement
parts for your next repair.
Shop on Amazon →
