White smoke coming from the exhaust
113,000 MILES • 1.6L • 4 CYL • TURBO • 2WD • MANUAL
AARON CLIFFORD
Hi there. I own the car listed above 1.6TDCI engine. There is white smoke coming from the exhaust. It doesn't happen all the time although it's becoming more regular. It happens when I ease off the accelerator, then big clouds of white smoke comes from exhaust.
Aug 7, 2019 at 11:01 PM
SCGRANTURISMO
  • 4,897 POSTS
White smoke from the exhaust is usually a sign that coolant is being burnt in the combustion chambers of your engine. Here are a couple of links below for you to go to:
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
This usually happens with a blown head gasket, but it can also be from a coolant crossover tube, on V6 and V8 applications, or a cracked cylinder head or cracked block. Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Aug 7, 2019 at 11:15 PM
