2000 Ford Focus White smoke
DANETTEROBINSON
Engine Cooling problem
2000 Ford Focus 4 cyl Two Wheel Drive Automatic
My son had a minor accident and he never got the car checked it was running fine until 2 days ago it started with the white smoke and he couldn't drive it. Now someone said it's the head gasket and someone else said replace the engine please help- me with the the smoke is coming from by the radiator?
Aug 11, 2010 at 12:22 PM
MMPRINCE4000
  • 8,548 POSTS
White smoke out the exhaust indicates a head gasket or possible intake manifold gasket.
A compression test will tell you if head gasket is problem.
Head gaskets can be changed, it would depend on if it is just a headgasket or a warped head.
Aug 14, 2010 at 1:48 AM
