Limp mode how can I fix it?
125,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
JAVAJOE73
While I am driving and holding the accelerator steady, the engine pauses for one second as if I had just released the accelerator. A couple of things I need to mention is that every so often for the last couple months when I go to start the engine it only cranks and I turn the key back to the off position and wait about thirty seconds and then it starts right up. The other thing I need to mention is the radio only works when it feels like it.The reason I am mentioning the radio problem is because my thought is that there is a slight possibility that there may be corroded connection at the ECM or the BCM. I am leaning towards the fuel pump starting to go. With this problem being intermittent, it makes it difficult to troubleshoot. Any thoughts would be greatly appreciated before i end up stuck on the side of the road needing a tow.
Feb 18, 2019 at 5:37 PM
  • 55,711 POSTS
It sounds like you have a dirty throttle bore causing the computer to lose correlation between the throttle sensor and throttle actuator we should run the codes though.
and
https://www.2carpros.com/articles/reduced-power-limp-mode
Feb 20, 2019 at 2:29 AM
