I ordered a new harmonic balancer. Crankshaft bore to big. Is there more then 1 size that can fit
Apr 6, 2016 at 9:14 AM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
HMAC300
AUTOMOTIVE REPAIR CONTRIBUTOR
it cold be just the wrong part we don't have specs on that
Apr 6, 2016 at 9:31 AM
NICKIDOUGLAS
MEMBER
The new one is what is listed for replacement but old is around 27m shaft bore
Apr 6, 2016 at 12:21 PM
HMAC300
well it may have something to do with production code later or earlier so you'll have to check into that. or if this was purchased used it may be different the ones I see for 5and 6 anre both 32 mm crank bore check with a dealer there may be something different for that specific year.
