When I bought the car, it started with a screwdriver?
200,000 MILES • V6 • 4WD • AUTOMATIC
APCUDA89
My car with a screw so I started my car with the screwdriver but then the battery drained and when I charged it I tried to start it with the screwdriver and it looked like it was going to start all the way up until the engine was supposed to turn over and the engine won't turn over, but all the lights and everything are on. So, I was trying to figure out how hot wire what two wires to use.
Aug 8, 2022 at 8:33 AM
  • 110,248 POSTS
I really can't provide that type of information online. I hope you understand.
So, if it won't start, is the anti-theft light staying on or flashing? If it isn't, then there is a chance we lost ignition spark or fuel to the engine.
Here is what to try:
See if the engine starts when you use starting fluid. If it does and then stalls, we know it is a fuel-related issue. If there is no change, then I need you to check for spark to the plugs. Here is a link that explains how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this and let me know what you find.
Aug 8, 2022 at 4:37 PM
