Engine will not start and check engine light turns on
186,000 MILES • 4 CYL
MONICAFLORES
my engine light comes on but my car wont start. what do i do? what needs to be done and how much will it cost?
Dec 4, 2020 at 7:31 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
The first thing that needs to be done is to check the diagnostic codes from the check engine light to determine what is causing the problem with your car. Here is a tutorial what is involved for checking diagnostic codes:
If you don't have access to a code reader or scanner auto parts stores have tool loaner programs and can rent you one. Auto parts stores like AutoZone can check codes for free. Once you perform this test get back to us with the code information and we can then properly diagnose what the issue is with going on with your car. Hope this helps and thanks for using 2CarPros.
Dec 4, 2020 at 10:35 AM
