While driving the overdrive light turns on and flashes
  • 110,053 POSTS
Okay, now I understand. Chances are the OD switch on the shifter is bad or the wiring in the shifter has broken. You will need to check it for continunity to see if first the wiring is good, and then if the switch breaks the current.
Saturday, April 11th, 2020 AT 11:55 AM (Merged)
CORCEL
  • 2000 FORD RANGER
  • 6 CYL
  • 75,201 MILES
This transmission shifts fine when first starting. After warm-up, it stays in first gear too long and jerks hard when shifting into second. After driving around town for most of the PM, the overdrive light came on and it seemed to stay in second gear. Since then, it has been working fine on short drives, but still jerks when shifting into second afer warm-up. Any ideas?
Saturday, April 11th, 2020 AT 11:56 AM (Merged)
FLEXY5
  • 512 POSTS
The valve body gaskets have a reputatin of blowing out. There use to be an updated gasket with the separator plate. Then It use to be only available with the valve body. Then there use to be a service kit that came with a new plate and gaskets as well as a valve kit to put in the valve body. I'm not sure how it is available now, but I'll bet that's your problem.
LOY WALKER
  • 1995 FORD RANGER
  • 6 CYL
  • 4WD
  • 125,000 MILES
Over drive light comes on and off sometimes, want come out of overdrive?
Thanks Loy;
  • 110,053 POSTS
Have you had the computer scanned to identify where the problem is coming from? Most parts stores will do it for free.
BIGJIM79
  • 239 POSTS
Theoverdrive solenoid is either getting a weak signal or no signal resulting in a faulty circut. Try and look at your fuses
CBSMITH
  • 1995 FORD RANGER
  • 4 CYL
  • 198,847 MILES
My O/D light comes on. After the truck warms up. It blinks continuously until the truck is parked and turned off. I have a button to push to turn off overdrive but it does nothing when the light starts blinking.
The truck's shifter is off and you have to move it to park to put in in reverse.
KEITHMESSER
I have the same thing going on with my Ranger did you fix yours? And if so How may I ask
Keithmesser@yahoo. Com
CBSMITH
Having transmission rebuilt to solve problem. I was afraid to drive it with this going on. I took it to a mechanic and he suggested that I go ahead and get the transmission rebuilt. We will see how it goes.
