2001 Ford Ranger Electrical problem
TALLONE
My ranger has 106,500 miles with a 3.0 L V-6. After ford disconnected my cruise control for the recall which they are suppose to fix later when they get the parts. The ABS light has been coming on, I had the airbag light come on and stay on once until I shut the vehicle off, I am now also getting the speedometer bouncing from 10 to 30 miles in park or when I am sitting at a stop light and the last thing was the ABS light started flashing instead of being steady and the radio was going off and coming on ( the display would go blank) with the flashing of the ABS light. It also took 3 tries of the ignition switch to get it to start once. The battery shows 12V and has 13.5V when the engine is running. although the battery is still the factory battery. I can't find any elstrical diaghrams of the wiring for the radio or the ABS system. Any ideas on what I can look for or check?
Oct 6, 2007 at 4:47 AM
BIZ505
Thanks alot for getting back to me, and I'll try cleaning out the radiator fins as you described! Just one question, wouldn't the temp guage read high in the vehicle if it was a radiator issue?
Jul 23, 2007 at 7:18 AM
BIZ505
I trust ya! Autozone didn't have any steel fuel lines, so I bought a steel brake line and used it instead. Thanks for the help, and I'll know if it does the trick after this weekend!
Jul 23, 2007 at 8:14 AM
BIZ505
Yeah I had to do 3 radiators. The engine, transmission, and the AC. Alot of crap in there for sure!
Jul 23, 2007 at 8:43 AM
